UKWelder FAQ - Knowledgebase
Gold Lenses
Gold coated welding lenses also known as gold mirror lenses have been available for a number of years.
A standard welding filter lenses is coated with a thin layer of gold which the manufacturers claim reflects 90% of the welding heat compared to only 4% with
a standard lens.
A second claim for the lenses is that they allow you to see the weld in it's true colours.
A third advantage is that they look really good !
Gold lenses are available from the UKWelder Shop in 2 sizes 52 x 108 mm and 90 x 110 mm and in a variety of filter shades. - Why not give one a try ?
Click Here to Buy
User Comments:
"I've been using them for about a year now and i think they are far better than the standard lens. i feel that i can wear a higher filter because of the light from
the arc is reflected back onto the job from the gold film on the lens but when you are welding you need to protect the gold lens so it is not damaged."   wee_dobber
"The gold lens is a fixed shade lens with a gold coating on the front not a cover lens they are superb but of no use to you if you use an auto screen." den the welder
"With the mirrored surface, they also reflect light back, which can make it easier to see.  I use them all the time....mig, tig, whatever I weld it's done with the
gold lenses."    Engloid
"Dont know about reflecting heat back, I haven't managed to boil my eyeballs with normal lenses. weird seeing stuff the right colour,but comfortable on eyes"    monkee
"They reflect more heat and allow you to see the weld in it's 'true' colours. I for one swear by them"
 BP
Would you like to...
Print this page Print this page
Email this page Email this page
Post a comment Post a comment
Subscribe me
Add to favorites Add to favorites
Remove Highlighting Remove Highlighting
Edit this Question
User Opinions (9 votes)
88% thumbs up 11% thumbs down
How would you rate this answer?
Helpful
Not helpful
Thank you for rating this answer.
Visitor Comments
  1. Comment #1 (Posted by DES the Diver )
    Use these lenses to wet-stick weld. Good vision is vital especially when the visibility is not great. So any advantage is useful. And they look good in the publicity shots!
Related Questions
No related questions were found.
No attachments were found.
