> What is Repair criteria for Burn through in SAW pipe
akbarnaich
post Jan 19 2018, 05:56 PM
Dear Experts,
please guide repair criteria of BT(arc burn in both welding inside and outside) in SAWH process
if root gape reached 22mm (18mm weld bead normally pipe size 1066*14.3mm) as per API 5L
Thanks
Ballbearing
post Jan 22 2018, 10:41 AM
I am not an expert but I will tell you what you have (if I have read your post correctly) - a major problem !!!
I have seen pipes being SAW welded on a rotator with GTAW or GMAW root and one little problem and you have a huge hole (melt through).
You will need a qualified repair procedure - no point asking on an internet forum
