Hi Arsham, I had a slight shifty at the link you posted and the material on there was probably the same level as the IWP (international welding practioner) niveau for here in Europe, which is above the NVQ level 3 Diploma in the UK. Whatever, if you aim high, the material learned will easily cover you for a lesser qualification. If their tests are anything like ours, it will be nearly all multipul choice questions but, without the course work you will find it difficult to gain a pass.
Hope this helps a little, Bb.
