I'll add more to this about filler metals...
Typically, anywhere that a weldment will see physical stress, including heat, filler metal should be used.
the reason is that metal is a compound that consists of many things. When you weld, everybody knows that certain gasses, metals, and vapors are released into the air. Also, some elements will tend to rise to the surface. Either of these reduces the amount of that element in the metal after the weld. Filler metals are typically made such that they have higher percentages of these elements that will be released into the air or will rise to the surface. By not using filler metal, your weld can be weaker than the base material.
In some industries like food process or pharmaceutical piping. filler metal may not be used.. but remember that this is usually thin tube that only has to hold itself up in the air.
