> Fillet weld procedure query
charpy+2
post Nov 8 2019, 01:40 PM
Hi All
Can anyone help.
We are working to 15614 Pt 1 on a job, and having an issue with the client. Our fillet weld procedures where made using the multi run technique, our client has told us they do not cover a single pass fillet and said we should re-submit a single pass fillet for approval. Is the client right in what he says?
post Nov 10 2019, 11:52 PM
I dont know what the Standard says but I would want a new procedure for a single pass fillet. The results can, and probably will, be very different.....all else being equal
charpy+2
post Nov 11 2019, 09:21 AM
Thanks Technic Al
I think you are right after re-reading the spec. Probably in for a rollicking now, as it was me that said go the multi-pass as it gave you no restriction on throat thickness size.
